PUES EMPECEMOS CON BOCINAS COAXIALES EN VARIAS MEDIDAS
4"MODELO S-402
• Power Handling Capacity (Peak) : 105W
• Power Handling Capacity (RMS) : 35W
• Nominal Impedancel : 4 ohm
• Frequency Response : 70Hz - 20kHz
• Sensitivity : 86 dB/W/M
• Motor Structure : 6 oz
• Mounting Depth : 1.8"
4X6 MODELO S-462• Power Handling Capacity (Peak) : 105W
• Mounting Depth : 1.95"
5 1/4 MODELO S-522
Power Handling Capacity (Peak) : 120W
• Power Handling Capacity (RMS) : 40W
• Frequency Response : 65Hz - 20kHz
• Sensitivity : 87 dB/W/M
• Motor Structure : 8 oz
• Mounting Depth : 2.0"
6 1/2 MODELO S65T
• Power Handling Capacity (Peak) : 135W
• Power Handling Capacity (RMS) : 45W
• Frequency Response : 63Hz - 20kHz
• Motor Structure : 10 oz
• Mounting Depth : 2.15"
6X8 MODELO S-682
• Power Handling Capacity (Peak) : 180W
• Power Handling Capacity (RMS) : 60W
• Frequency Response : 56Hz - 20kHz
• Sensitivity : 98 dB/W/M
• Mounting Depth : 2.35"
6X9 MODELO S-693
• Power Handling Capacity (Peak) : 210W
• Power Handling Capacity (RMS) : 70W
• Frequency Response : 45Hz - 20kHz
• Sensitivity : 90 dB/W/M
• Motor Structure : 20 oz
• Mounting Depth : 3.3"
[b]
4"MODELO S-402
5 1/4 MODELO S-522
6 1/2 MODELO S65T
6X8 MODELO S-682
6X9 MODELO S-693
[b]Última edición por dr booms el Vie 07 Ago 2009, 3:33 pm, editado 1 vez
